Willie Posted September 27, 2010 Share Posted September 27, 2010 Has anyone personally performed a tire rotation along with the procedure for resetting the tire pressure monitoring system? If so, how did it go for you? I ask because I’m considering doing this soon. Quote Link to comment Share on other sites More sharing options...
JWWOODY Posted September 27, 2010 Share Posted September 27, 2010 PLEASE READ IN THE TIRE AND WHEELS SECTION FOR THE TPMS RESET PROCEEDURE, AND FOLLOW THE ROTATION STEPS IN THE OWNERS MANUAL. SINCE IF HAVE DIFFERENT WHEELS WITH DIRECTIONAL TIRES, I ROTATE MINE FRONT TO BACK ON THE SAME SIDE. I DO IT EVERY 10,000 MILES AND RESET THE PRESSURES ACCORDINGLY. WOODY Quote Link to comment Share on other sites More sharing options...
Willie Posted September 28, 2010 Author Share Posted September 28, 2010 Well of course I read the directions for the procedure, which is why I was asking about anyone else’s experiences with it. Anyone? Quote Link to comment Share on other sites More sharing options...
ncranchero Posted September 28, 2010 Share Posted September 28, 2010 Rotated mine last week, no problems. I have the "reset tool" from my E250 and followed the instructions in the manual for entry into the training process, then reset them holding the tool AT the stem, instead of 180 degrees off that my E250 specified. Quote Link to comment Share on other sites More sharing options...
Willie Posted September 28, 2010 Author Share Posted September 28, 2010 Now we’re getting somewhere! Thanks NC. What does the tool do? Quote Link to comment Share on other sites More sharing options...
ncranchero Posted September 29, 2010 Share Posted September 29, 2010 It simply resets the wheel pressure sensors to the proper "setting" when you rotate your tires. 36psi front/49psi rear. Quote Link to comment Share on other sites More sharing options...
mike56 Posted October 1, 2010 Share Posted October 1, 2010 It simply resets the wheel pressure sensors to the proper "setting" when you rotate your tires. 36psi front/49psi rear. where do you get a reset tool??? I have had my Transit for only a few weeks. Quote Link to comment Share on other sites More sharing options...
ncranchero Posted October 1, 2010 Share Posted October 1, 2010 (edited) I'd try eBay or Craigslist because FOMOCO is proud of them from what I've heard. http://cgi.ebay.com/ebaymotors/FORD-OEM-TIRE-PRESSURE-MONITOR-RESET-TOOL-TPMS-RESET-_W0QQcmdZViewItemQQhashZitem43a0569c3bQQitemZ290452839483QQptZMotorsQ5fAutomotiveQ5fTools I'd have to look a while or try the magnet trick before paying $40 for one. Edited October 1, 2010 by ncranchero Quote Link to comment Share on other sites More sharing options...
