john01 Posted February 11, 2010 Share Posted February 11, 2010 Hey guys is there any way to keep the rear door from staying locked? Every time we get out we can open the sliding doors but have to always unlock the rear and digging for keys with stuff in your hands can be a pain. Thanks. Quote Link to comment Share on other sites More sharing options...
kmoilan1 Posted February 11, 2010 Share Posted February 11, 2010 (edited) I am guessing you have the remote entry key fob/power locks. If you do, you can set it to one step unlocking as follows and is noted in the manual page 63. Switching from two step to one step door unlocking Your vehicle comes with two step unlocking enabled. With the vehicle locked, unlocking can be switched between two step and one step door unlocking by pressing and holding both the lock and unlock buttons simultaneously on the remote entry transmitter for approximately four seconds and release. The turn signal lamps will flash twice to indicate that the vehicle has switched to one step unlocking. Repeat the procedure to switch back to two-step unlocking. Once this is done, it enables the cargo doors to unlock from the interior along with the front and sliding doors. Even though I haven't found it noted in the manual regarding this setting affecting unlocking from the interior, it has worked for me. Give it a try... Edited February 11, 2010 by kmoilan1 Kdash and Rusty the Scoob 2 Quote Link to comment Share on other sites More sharing options...
john01 Posted February 11, 2010 Author Share Posted February 11, 2010 Yes I do have the remote key fob thing and I will give it a try. Thanks for your help I really appreciate it. Quote Link to comment Share on other sites More sharing options...
scottacus1100 Posted February 12, 2010 Share Posted February 12, 2010 Thank you so much for this!!!!!! Quote Link to comment Share on other sites More sharing options...
humitex Posted February 13, 2010 Share Posted February 13, 2010 I am guessing you have the remote entry key fob/power locks. If you do, you can set it to one step unlocking as follows and is noted in the manual page 63. Switching from two step to one step door unlocking Your vehicle comes with two step unlocking enabled. With the vehicle locked, unlocking can be switched between two step and one step door unlocking by pressing and holding both the lock and unlock buttons simultaneously on the remote entry transmitter for approximately four seconds and release. The turn signal lamps will flash twice to indicate that the vehicle has switched to one step unlocking. Repeat the procedure to switch back to two-step unlocking. Once this is done, it enables the cargo doors to unlock from the interior along with the front and sliding doors. Even though I haven't found it noted in the manual regarding this setting affecting unlocking from the interior, it has worked for me. Give it a try... Thanks for the tip...guess some of us, including me..should read the manual...LOL Quote Link to comment Share on other sites More sharing options...
isellford Posted February 13, 2010 Share Posted February 13, 2010 Duh! Is that why Ford give you one. Also at time of delivery, the salesperson is supposed to go over a checklist and show you al of the intracacies of the vehicle. Quote Link to comment Share on other sites More sharing options...
bikehauler Posted June 3, 2010 Share Posted June 3, 2010 by pressing and holding both the lock and unlock buttons Ah, but which unlock button? There are two--one for the passenger doors and one for the rear doors. Quote Link to comment Share on other sites More sharing options...
aircuda Posted August 9, 2010 Share Posted August 9, 2010 Thank you, thank you, thank you! I asked the Ford dealership this very thing and they said you can not change this. Maybe I should read the manual also. B) Quote Link to comment Share on other sites More sharing options...
ncranchero Posted August 9, 2010 Share Posted August 9, 2010 (edited) Stepped Unlock Programming With the ignition switch in the OFF position, press the LOCK and UNLOCK buttons on the Remote Keyless Entry (RKE) transmitter simultaneously for 4 seconds. The turn signals flash twice to indicate the mode change. Repeat Step 1 to enable/disable the stepped unlocking feature. Edited August 9, 2010 by ncranchero Quote Link to comment Share on other sites More sharing options...
TClary Posted August 26, 2010 Share Posted August 26, 2010 I am guessing you have the remote entry key fob/power locks. If you do, you can set it to one step unlocking as follows and is noted in the manual page 63. Switching from two step to one step door unlocking Your vehicle comes with two step unlocking enabled. With the vehicle locked, unlocking can be switched between two step and one step door unlocking by pressing and holding both the lock and unlock buttons simultaneously on the remote entry transmitter for approximately four seconds and release. The turn signal lamps will flash twice to indicate that the vehicle has switched to one step unlocking. Repeat the procedure to switch back to two-step unlocking. Once this is done, it enables the cargo doors to unlock from the interior along with the front and sliding doors. Even though I haven't found it noted in the manual regarding this setting affecting unlocking from the interior, it has worked for me. Give it a try... You are my Hero! T Quote Link to comment Share on other sites More sharing options...
mike56 Posted September 8, 2010 Share Posted September 8, 2010 Thanks for the tip...guess some of us, including me..should read the manual...LOL thank you me too Quote Link to comment Share on other sites More sharing options...
kmoilan1 Posted September 8, 2010 Share Posted September 8, 2010 (edited) 'bikehauler' date='03 June 2010 - 02:02 PM Ah, but which unlock button? There are two--one for the passenger doors and one for the rear doors. If one looks at the KEY FOB note the lock icon and the unlock icon . Ignore the deck release icon... %^) I do not have passenger door or rear door icons on my FOB. Edited September 8, 2010 by kmoilan1 Quote Link to comment Share on other sites More sharing options...
STxFarmer Posted October 11, 2010 Share Posted October 11, 2010 Thanks for the directions, that was way too easy. Quote Link to comment Share on other sites More sharing options...
Stan MI Posted November 10, 2010 Share Posted November 10, 2010 Thanks for the directions, that was way too easy. Thanks !! Sad part is I read it in the manual and didn't think this was what they meant so I didn't try it. Quote Link to comment Share on other sites More sharing options...
surfer99 Posted October 30, 2011 Share Posted October 30, 2011 Ok I got the doors to all unlock with ONE STEP from the inside,.... when I get OUT of the TC all the doors unlock...... however I can't get all the doors to unlock with ONE STEP using the remote from the outside, I have to push the cargo button first which opens the cargo door then I have to push the door unlock button which opens the rest of the doors, any ideas. ...... Is there a way to stop the horn from sounding when I lock the car? Quote Link to comment Share on other sites More sharing options...
dayspring Posted March 5, 2014 Share Posted March 5, 2014 T want to disable the auto locking feature altogether. Anyone know how to do this? Quote Link to comment Share on other sites More sharing options...
