Sign in to follow this
No name displayed
Jerking
Have a 2018tc cargo. 2.5 motor. 50k miles. Upon light to medium acceleration I get soft jerking/shaking the whole vehicle. Hard accel yes fine. Motor runs great. Spark is good and so is intake and maf sensor. I don’t know what it could be. Thanks for any help
Tire(s) or CV-joint/axle shaft.
I have new tires about 2 weeks old. But I can bring it back to shop
Did this issue start before or after the tires? If after check the balance , and Make sure the Lug Nuts are tight.
let us know what you find.
Took back to tire place and all checked out good. Although they didn’t remove and shafts or anything. Still same. Hasn’t got worse or better.
Does that mean the tires? If so they should be put back on the balance machine..
Honda has this issue in their 5-speed autos, a bad torque converter.
