kirkshonk@gmail.com Posted February 8, 2020 Share Posted February 8, 2020 Hi Anyone No the correct Part # for the roof plugs that cover the roof rack holes Ford keeps getting The wrong ones Thanks ! Quote Link to comment Share on other sites More sharing options...
PWFX Posted February 9, 2020 Share Posted February 9, 2020 I needed those plugs for my 2018 TC. Went to a dealer, looked at the parts schematics, turned out there's actually 3 different sizes that are used, each size comes in a pack of 4. Quote Link to comment Share on other sites More sharing options...
kirkshonk@gmail.com Posted February 9, 2020 Author Share Posted February 9, 2020 thanks for the reply I have been to the deal the schematic is horrible I have 2 different part #s on order the 1st one they got was completely wrong. mine is leaking water in to the drivers side rear cup holder funny they all look the same it was a bugger to get the old 1 out when You installed your new ones do they just pop in like a normal push pin? Quote Link to comment Share on other sites More sharing options...
PWFX Posted February 9, 2020 Share Posted February 9, 2020 They easily pop in. Almost felt a bit too easy... but have driven through major storms with no leaks. All 3 different plugs look very similar in person, and identical on the schematics... but they are all slightly different. Quote Link to comment Share on other sites More sharing options...
Redvanman Posted February 15, 2020 Share Posted February 15, 2020 Any luck getting the correct parts? If yes, please post the part mumbers here. I need a full set, the prior owner of my 2015 van removed the plugs and gummed the holes with scrap bolts and silicone.... I want to fix right. Thanks!!! Quote Link to comment Share on other sites More sharing options...
TCjeff Posted July 25, 2020 Share Posted July 25, 2020 On 2/15/2020 at 5:38 PM, Redvanman said: Any luck getting the correct parts? If yes, please post the part mumbers here. I need a full set, the prior owner of my 2015 van removed the plugs and gummed the holes with scrap bolts and silicone.... I want to fix right. Thanks!!! Did you ever figure this out? Quote Link to comment Share on other sites More sharing options...
Jimmyc1163 Posted August 20, 2020 Share Posted August 20, 2020 I'm also struggling to find the right parts. Previous owner must have had a roof rack fitted and when they removed it they just taped up the holes (badly). Now when it rains my stuff is getting wet! Quote Link to comment Share on other sites More sharing options...
PWFX Posted August 20, 2020 Share Posted August 20, 2020 To get the parts, I just went to my local Ford dealer. It was quick and easy. Tried to find them online and could not figure it out. As I posted earlier... there are 3 different sizes that need to be ordered. TCjeff 1 Quote Link to comment Share on other sites More sharing options...
Jimmyc1163 Posted August 31, 2020 Share Posted August 31, 2020 Last week I visited the local Ford parts dealer. Turns out the required plugs actually show up on the side body panel drawings, not the roof panel drawings. We discovered there are many different plugs shown on the drawing. I was only missing two types, the small round ones at the front and the oval shaped ones along the roof. Part numbers are 5288738 and 5288591. Easily found on ebay, but slightly cheaper direct from Ford (although I'm still waiting for the order to come in). Here's a link to the drawing showing the different plugs available: https://ford.7zap.com/en/transport/163/no/0/2699/20301/90153/ TCjeff and jrm223 2 Quote Link to comment Share on other sites More sharing options...
MLB Posted October 6, 2020 Share Posted October 6, 2020 They are "cheese dick" (cheap) little pieces of plastic. Wouldn't knock yourself out to get them. A bolt and rubber washer be a lot tighter. Quote Link to comment Share on other sites More sharing options...
