Best repair for roof plug leak
I have a Ford Transit Connect 2014 XLT Long wheelbase blue with black roof plugs on the railing. One of them is cracked and leaks. I'm trying to fix the issue.
a) I can't find the plug replacement. Any leads to a website or part number?
b) How to dry and absorb the water?
c) Should I use a sealant like Great Stuff before covering it again?
d) Should I use Eternabond or duct tape to cover the plug?
e) If I can't find plugs, is it enough with sealant and tape?
f) Depending on what I use, would it be easy to remove if the next owner or I want to install a rack?
Thanks!
