I hate drum brakes!
Had to do the rear brakes on the companies 2013 Transit Connect last night... What a disaster! Why couldn't Ford just use normal spring pins instead of making me fight to get all of the springs connected between the shoes?!?! Granted, bad lighting in my garage probably didn't help ?. I discovered this morning that I need to pull the tires back off and readjust them, I thought I had gotten them adjusted properly until I pulled the e-brake, LOL! (either that or one of the cables came off).
On 4/4/2019 at 1:14 AM, davidparker said:
Well, I guess the good news is you probably will never have to change them again!
Hopefully not, but I'm only at ~71K, so (assuming van doesn't fall apart, or company gets tired of doing maintenance/repairs on the van) we'll see...
Also, discovered why the e-brake (and rear brakes in general) stopped working a bit after I got done working on them, the self-adjuster failed. Appears to have been a manufacturing defect...
