Kirky229 Posted October 16, 2018 Share Posted October 16, 2018 (edited) I have a 2004 transit connect with a tddi engine. The body is ruff so I want to fit my engine in a newer year. If the van I am fitting it in has a tdci engine then will my tddi engine fit or are the Mounts different. Any help would be very useful. Rob Edited October 16, 2018 by Kirky229 Quote Link to comment Share on other sites More sharing options...
mountainman Posted October 16, 2018 Share Posted October 16, 2018 I'm curious about this too, though I'm wondering if the diesel engines in the 2019 vans can be installed in older models. Quote Link to comment Share on other sites More sharing options...
Denis Posted April 10, 2019 Share Posted April 10, 2019 I have a 2014 connect t200 the engine has failed was fine , the made a ticking sound followed by knocking and stopped 3 bent inlet valves and 3 cracked pistons .problem is I can’t see why everything looks fine can belt is good and was tight with no sign of slipping any ideas please Quote Link to comment Share on other sites More sharing options...
G B L Posted April 11, 2019 Share Posted April 11, 2019 I do not have any pictures of the engine you have. Is the Camshaft driven by a toothed rubber belt or a Chain. In any event if the tensioner was not doing its job 100% it could allow the timing to Jump and might not wreck the belt. Quote Link to comment Share on other sites More sharing options...
mrtn Posted April 11, 2019 Share Posted April 11, 2019 Sounds like a tensioner malfunction if the belt was good. Quote Link to comment Share on other sites More sharing options...
