ActiveIndy Posted June 2, 2018 Share Posted June 2, 2018 Anyone else had to replace the rocker panels on their Transit Connect? I have a 2010 and one side has rusted all the way through, the other has started rusting. Took it to a reputable collision center here in Indianapolis and they shared that OEM rocker panels are the only ones available - at $1800 each...then labor on top of that. That was just the first quote I've obtained, but it was north of $5k. Just curious if I'm the only one out there that is dealing with rust in this location and whether anyone else has sourced less expensive parts...thanks! Quote Link to comment Share on other sites More sharing options...
Beta Don Posted June 2, 2018 Share Posted June 2, 2018 If it's a 2010, it probably has enough miles on it that you're looking to spend big money on some other things over the next few years, so any major expense (and replacing the rockers will be a major expense unless you can source some junkyard parts and do the work yourself) probably means that 'the end' is on the horizon for that vehicle I know I wouldn't invest even $2K replacing the rockers when the near future will probably mean more money for suspension or transmission work - You'll be 'throwing good money after bad' I would start making plans on what the replacement is ultimately going to be Don Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted June 2, 2018 Share Posted June 2, 2018 Get a second or third quote. Look up the part numbers online to see if you can find a better price. Quote Link to comment Share on other sites More sharing options...
mrtn Posted June 3, 2018 Share Posted June 3, 2018 TC rocker panels are stupid simple. Any good body shop will bend you a pair in an hour.. Quote Link to comment Share on other sites More sharing options...
