hugomax Posted September 29, 2017 Share Posted September 29, 2017 Hi guys I bought a 2005 VJ Transit recently with the initiation to convert it into a camper and it has a fault I hope I can get some help with. After a short drive, the heater coil light starts flashing then the engine dies and then cuts out. While rolling to a stop I can put the clutch down and start it up again. And then it does it again a few hundred metres later. Next stop is to a mechanic to get it on a computer but it would be great if anyone has any ideas. Quote Link to comment Share on other sites More sharing options...
mrtn Posted September 29, 2017 Share Posted September 29, 2017 The engine coil light flashing means "check engine". May be numerous things: clogged filter or a bad pump. The error code will give you more hints. Quote Link to comment Share on other sites More sharing options...
G B L Posted September 29, 2017 Share Posted September 29, 2017 Mrtn is correct you need a scan first. Quote Link to comment Share on other sites More sharing options...
