Sharon85 Posted March 3, 2016 Share Posted March 3, 2016 Hi all. New here. I have a 2015 titanium connect. Love it. Bought it new with about 20 miles on it flash forward to the past 8 months, I'm at about 50k miles. When I turn the key in the ignition and start the engine the entire front end will "shake" as if it is going to stall out but it never has. If I have my foot on the brake BEFORE turning the ignition, it will never do it. If I put my foot on the accelerator WHILE it is shaking it will immediately stop. It ONLY does it on ignition, never while idling or moving. It has been in to the dealer, and they did a computer reset which stopped the problem for roughly 2 months, then it's started back up, occasionally at first and now almost every time I start it. Thoughts? Quote Link to comment Share on other sites More sharing options...
Sharon85 Posted March 3, 2016 Author Share Posted March 3, 2016 It's definitely neither of those two recalls. Quote Link to comment Share on other sites More sharing options...
G B L Posted March 3, 2016 Share Posted March 3, 2016 When it shakes what are the RPM's, Just a wild guess, The Idle air control is too low and when you have your foot on the brake it is causing the computer to raise the idle. Stepping on the gas will do the same thing, once the revs are good it is happy. You might also check the, Spark plugs if they have not been changed. keep us posted. LostInTransit 1 Quote Link to comment Share on other sites More sharing options...
mrtn Posted March 3, 2016 Share Posted March 3, 2016 On 3/3/2016 at 5:54 PM, G B L said: When it shakes what are the RPM's, Same question - do the rpm drop or is it losing a cylinder or two. Quote Link to comment Share on other sites More sharing options...
Sharon85 Posted March 3, 2016 Author Share Posted March 3, 2016 The RPMS are lower than 1k. However transit connects are not equipped with an IAC, it's controlled by an electronic throttle body. Quote Link to comment Share on other sites More sharing options...
mrtn Posted March 3, 2016 Share Posted March 3, 2016 800-900 are correct rpm. There have been several reports of diesel TC electronic accelerator pedals failing and causing all kinds of engine speed problems. Not sure if it's the same unit tho. Quote Link to comment Share on other sites More sharing options...
G B L Posted March 4, 2016 Share Posted March 4, 2016 When it is shaking are the Rpm's the same as after the accelerator is pressed and released? As the electronic throttle is taking the place of the IAC then the resting position for the throttle plate could be on the low side and could cause a low Idle How long will the shaking continue if you do nothing? Mine did the same thing once on a quick restart so I will have to pay attention. Quote Link to comment Share on other sites More sharing options...
Sharon85 Posted March 4, 2016 Author Share Posted March 4, 2016 I would say it last 10 to 15 seconds if I do nothing. Quote Link to comment Share on other sites More sharing options...
G B L Posted March 4, 2016 Share Posted March 4, 2016 Then it is Ok? Then no symptoms until the next start? Did the dealer have the symptoms happen with a scanner hooked up? What happens if when you turn the key on you cycle the Switch a second time to start it? Quote Link to comment Share on other sites More sharing options...
