How to remove crossbars?
Can anyone tell me how to remove the stock crossbars from the roof rack on my 2015 TC? There's no info in the manual and a search here doesn't show anything. I've never removed a rack before, so I'm not sure where the feet can be loosened. I'd like to take them off until I need them.
And to a small extent they'll move side to side. You'll see once you get them off. So if say you wanted to hang something more to one side or the other there's a small amount of movement.
I have a Yakima Skybox and bike mounts to fit mine. For those with rails but no factory crossbars Yakima Railgrabber mounts work on ours.
And someone asked if you can remove the factory rails without removing the headliner and my answer is : Not that I can see, I see no fasteners from the top unless they're stealthily hidden under the ends but I can't see how.
