Workin Wagon Posted September 22, 2010 Share Posted September 22, 2010 Does anyone know of a HID conversion kit for the TC? Or where to find LED's for all the other lights (inside and out) on the TC? Quote Link to comment Share on other sites More sharing options...
zepper Posted September 23, 2010 Share Posted September 23, 2010 Ebay has ooooodles of HID kits and LED lights. Just make sure you check feedback as not all HID kits are created equally. There was another member here who had replaced all interior lights with LEDs already--looked sharp. Let us know which ones you decide on. You should also post up install sequence pix for others. Quote Link to comment Share on other sites More sharing options...
brueg Posted August 24, 2013 Share Posted August 24, 2013 Just installed a HID kit. Haven"t driven with them yet, but while I was installing I had one on the drivers side and the stock one on the passenger side and the difference was huge.The kit was easy to install. Even with the sometimes odd translations in the manual. Heres one. Please fix the stabitity instrument tightly with double-sided tape and make sure both ends are firm. The only mod is to the round cover on the back of the headlight casing. You have to drill a 1+1/8 hole in them to feed the connectors through. I used silicone to glue a piece of bicycle tube over the hole when I was done. Probably wasn't necessary. The cover wasnt weather tight to begin with. When I get a chance I'll let you know what they are like on the road or if I have any problems. I took a short video on the way to work last week so I could compare the lights, but It will be a couple of weeks before I'm back on dayshift.When I get the second video I will attempt to post them. The kit is - HID Xenon Headlight "Slim" Conversion Kit by SDX, H13 Dual-Beam Bi-Xenon, 5000K Quote Link to comment Share on other sites More sharing options...
Raincity Posted August 31, 2013 Share Posted August 31, 2013 Fitting HID's into OEM reflector housings creates glare for oncoming traffic. I haven't seen any projector/HID housings headlights in North America, or even any ebay knockoffs. Quote Link to comment Share on other sites More sharing options...
brueg Posted September 5, 2013 Share Posted September 5, 2013 No one has flashed their brights at me. These are low beam pics. High beams are unbelievable. Quote Link to comment Share on other sites More sharing options...
CrazySwede Posted October 5, 2013 Share Posted October 5, 2013 What kind and brand of HID kit did you use and what power? 35watt? CrazySwede Quote Link to comment Share on other sites More sharing options...
mrtn Posted October 5, 2013 Share Posted October 5, 2013 Saw some cool ones here: http://fordtransit.org/forum/viewtopic.php?f=54&t=134533 Quote Link to comment Share on other sites More sharing options...
brueg Posted October 21, 2013 Share Posted October 21, 2013 The kit is - HID Xenon Headlight "Slim" Conversion Kit by SDX, H13 Dual-Beam Bi-Xenon, 5000K. Still no problems. Quote Link to comment Share on other sites More sharing options...
