Drifter Posted September 5, 2014 Share Posted September 5, 2014 My 2012 transit connect is running rough. It starts fine on high idle then when goes to low idle it drops to 750 rpm and runs real rough. My code reader says "Misfire Cylinder 3" I have changed plugs and put a new coilpack on cylinder 3 and does not help. the van runs fine on highway but idles bad when stopped. The van has 175000 miles and has been a maintence nightmare. Any suggestions??? Quote Link to comment Share on other sites More sharing options...
mustang Posted September 5, 2014 Share Posted September 5, 2014 when was the egr valve serviced last . that will do what your symptoms are . they generally need service/ cleaning every 60k or so miles Quote Link to comment Share on other sites More sharing options...
vitalys Posted February 5, 2015 Share Posted February 5, 2015 How do you service EGR? I have my jerks and stumbles around 2200 rpm. No codes come up. I have 162k miles on my 2012 transit. Quote Link to comment Share on other sites More sharing options...
escobar Posted April 29, 2015 Share Posted April 29, 2015 im having the same problem. I did a compression test and found that cylinder has only about 85psi where the others have close to 200. I am going to replace the rings on the piston. Can this be done from dropping the oil pan? thanks Quote Link to comment Share on other sites More sharing options...
Roberts801 Posted June 28, 2022 Share Posted June 28, 2022 Did anyone find a solution to the misfire? I have a 2014 Transit Connect XLT 2.5l. Replaced EGR valve, test drove, everything was fine. Decided to do plugs and coil packs now cylinder #3 has a misfire. Checked gap and swapped around coil packs and same issue. Quote Link to comment Share on other sites More sharing options...
G B L Posted July 19, 2022 Share Posted July 19, 2022 (edited) Wet and Dry compression test will tell alot. Edited July 19, 2022 by G B L Quote Link to comment Share on other sites More sharing options...
