GoDolly Cargo Handler - Suited to TC - Needs Beta Testers in Boston
Are You Interested? Keep Your GoDolly When We’re Done!
Enables One Person to lift heavy cargo, Inserting into the vehicle,
Extracting from the vehicle, Moving on the ground. Three-belt
winch system provides the power and applies it selectively.
  • Simple—Hand crank operated, with driver/drill power optional
  • Efficient—Weighs 75 pounds, carries/lifts 1000 pounds distributed
  • Convenient-Removable wheels for easy loading/unloading
  • Ergonomic-Webbing for lifting & hauling is easy on hands
  • Customizable-Plywood platform easily drilled: 62 x 29 inches
  • Fits TC – Length 72 inches, width over axles 32 inches
  • Passes 36 inch doorway: width over axles 32 inches
  • Folds flat for transport or storage. Integrated jack
  • No permanent attachment to vehicle
Please visit GoDolly.CO
Email Rich@GoDolly.CO
Phone Rich Dallmeyer at 617-332-7520
Edited by RichD
interesting. How long did it take to load the mower?
Mower weighs 325 pounds. Demo used 18 v. driver in low gear. Lift and Insert takes a couple minutes. Many factors influence time: hand crank vs. driver, gear ratio of winch drive, operator's experience. Thank you for your question.
Edited by RichD
Very ingenious, Rich. It looks like a nice item for most any Connect owner. What is the retail price?
It is too early to talk about price; Highest quantity in which I purchased any component so far is ten. I need Beta Tester for any idea of market traction. Thank you for your kind remarks.
Edited by RichD
  • 2 months later...
  • 1 year later...
Work out a way to reattach the hooks to the rear floor tie down points.
Then you could use the motor to pull the dolly back out also.
And depending on the geometry involved, it may be possible to control how the front lifts up also.
Then you would have control of how the back drops to the ground.
Another option would be to make the straps a continuous loop with the hooks in the middle.
The you could move the dolly back and forth as needed just by reversing the drill.
Here's a quick sketch I did of the picture I saw in my head as I watched the video.
post-5019-0-03663600-1436963034_thumb.jp
Edited by DonShockley
