tinman Posted February 28, 2025 Share Posted February 28, 2025 Having a hard time figuring out how to diagnose which sensor is the one saying its open. It would be really helpful to know where the module is that controls the door open protocols. Has anyone successfully jumped out the door sensors? At the module? Only locally at the switch? Obviously buying a $300+ door latch is out of the question when the only issue is that it reads as open. If anyone has any advice on how to proceed with this process it would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Nancy444 Posted March 18, 2025 Share Posted March 18, 2025 I am having the same issue. I think it's my passenger front door and driver's sliding door. I try to lock it with the fob and it locks and then unlocks and the light is on that a door is open. Ugh. Quote Link to comment Share on other sites More sharing options...
tinman Posted May 27, 2025 Author Share Posted May 27, 2025 obviously this group is either not very active or the people are not very helpful or dont know much Quote Link to comment Share on other sites More sharing options...
windguy Posted May 27, 2025 Share Posted May 27, 2025 4 hours ago, tinman said: obviously this group is either not very active or the people are not very helpful or dont know much or maybe it's because nobody cared for the TIN MAN. Now if it was Dorothy, it would be another story. 🙄 It would be helpful to know what model year your TC is (Gen 1 or 2)? Which door(s)? There has been some discussion over the years regarding door sensors. Give the search option a try. Quote Link to comment Share on other sites More sharing options...
JackGrimshaw Posted May 28, 2025 Share Posted May 28, 2025 Door sensors are on all vehicles and TC owners are very small subset. I suggest you search a wider audience to get a better understanding of how to troubleshoot any door sensor. I'm sure the technology is pretty standard across all vehicles. Quote Link to comment Share on other sites More sharing options...
Double Nickels Posted May 28, 2025 Share Posted May 28, 2025 On 5/26/2025 at 11:45 PM, windguy said: maybe it's because nobody cared for the TIN MAN That's what I am thinking. windguy 1 Quote Link to comment Share on other sites More sharing options...
tcmanny Posted June 3, 2025 Share Posted June 3, 2025 all i do is when get out of my car i open the passenger side door and close it, and that fix it Quote Link to comment Share on other sites More sharing options...
BSFixFTC Posted November 18, 2025 Share Posted November 18, 2025 lol, tinman taking shots at the community having this issue on 2012 and from researching it is common -sensors dirty < try spraying/cleaning locking mechanisms w wd40 -wiring issues < try using a multimeter to determine which is bad or acting up -replace mechanisms < salvage yard probably best price (test if fail return), eBay more $, but no guarantees -bypass sensor at wiring harness < see wiring guide & online videos (below is one) https://youtu.be/lsyo_tKNInY?si=dq8zs6gkjS18c26a Quote Link to comment Share on other sites More sharing options...
BSFixFTC Posted November 18, 2025 Share Posted November 18, 2025 lol, tinman taking shots at the community having this issue on 2012 and from researching it is common -sensors dirty < try spraying/cleaning locking mechanisms w wd40 -wiring issues < try using a multimeter to determine which is bad or acting up -replace mechanisms < salvage yard probably best price (test if fail return), eBay more $, but no guarantees -bypass sensor at wiring harness < see wiring guide & online videos (below is one) this might even be better: fix each lock mechanism by replacing internal motor < link to post here on forum windguy 1 Quote Link to comment Share on other sites More sharing options...
TrannyfromCali Posted 17 minutes ago Share Posted 17 minutes ago I had this same issue. I ended up removing the fuse because I kept having to open and slam doors 20+ times for it to lock. Now I just lock and unlock them all manually. A bit of a pain but at least now I can lock the car! Quote Link to comment Share on other sites More sharing options...
