jphphoto Posted November 21, 2022 Share Posted November 21, 2022 Hi all, Happy to say I found a fairly solid FTC with ~140,000 miles. First order of business is replacing the engine/tranny mounts, reattaching heat shields and checking/replacing the rear brake pads + drums(?). Looking forward to sprucing it up a little and decking it out for some camping and dirt bike weekends. I'll do some searches and get to know the forum a little. I am in search of rear passenger seats if anyone has any. It has the mount points but previous owner remove/discarded all but the single, passenger-side seat. Thanks, Jason windguy 1 Quote Link to comment Share on other sites More sharing options...
jphphoto Posted November 22, 2022 Author Share Posted November 22, 2022 Starting a list of things to check on my 2010 Grey XLT. THANKS for this post. Quote Link to comment Share on other sites More sharing options...
windguy Posted November 22, 2022 Share Posted November 22, 2022 Welcome to the forum and congrats on your new to you TC. It's not official until you post a pic of your new ride. As you pour over threads on this forum, you will find lots of discussion about the importance of proper transmission maintenance. Stands true for both Gen 1 and Gen 2 TC. Something to consider sooner rather than later if you didn't inherit good maintenance records for the van, especially with 140K miles on the van. Good luck! Quote Link to comment Share on other sites More sharing options...
lowspeedpursuit Posted November 22, 2022 Share Posted November 22, 2022 (edited) Does that recall apply to 1st-gens? I know it says 2013+, which is a weird cutoff, and I see a post that says "expanded to all models", but it references the 6-speed auto trans, and my shifter cable doesn't look anything like kruss77's pictures. Do we use the same bushing inside? EDIT: We do not appear to. I don't see how our bushing even comes out, and the manual lists the adjuster (the whole black bit) as part of a complete cable assembly part# 8S4Z-7E395-AG. Edited November 22, 2022 by lowspeedpursuit picture jphphoto 1 Quote Link to comment Share on other sites More sharing options...
mrtn Posted November 22, 2022 Share Posted November 22, 2022 That's for Gen2 only. Quote Link to comment Share on other sites More sharing options...
lowspeedpursuit Posted November 22, 2022 Share Posted November 22, 2022 (edited) Sweet, thanks. In the interest of preventative maintenance, I stopped by local Ford Parts on my way home to see if a Gen1 bushing is sold separately. I think OP's confusion is understandable, because parts barely knew what the hell was going on. One mention of TC shifter bushings and they wanted to give me the Gen2 stuff, even when I insisted that I drove a 2010 and those parts weren't right. It looks like maybe they don't index the Gen2 bushing by application; it's only sold separately from its cable because of the recall. In any event, they told me that the Gen1 shifter cables are in the process of being obsoleted, and there are currently 10 remaining on Ford shelves in the entire country. Dealer price is ~$80. So, if you do manage to break one, good luck with that. Edited November 22, 2022 by lowspeedpursuit Quote Link to comment Share on other sites More sharing options...
jphphoto Posted November 22, 2022 Author Share Posted November 22, 2022 6 hours ago, windguy said: Thanks, I'll put some photos up once I'm off the work computer and the sun comes back out. "It's not official until you post a pic of your new ride." As you pour over threads on this forum, you will find lots of discussion about the importance of proper transmission maintenance. Stands true for both Gen 1 and Gen 2 TC. Something to consider sooner rather than later if you didn't inherit good maintenance records for the van, especially with 140K miles on the van. Good luck! The PO replaced the transmission around 130K along with the timing belt and water pump. I'll keep an eye on it and search the forum for preventative transmission maintenance. 6 hours ago, windguy said: Quote Link to comment Share on other sites More sharing options...
