ncranchero Posted August 1, 2012 Share Posted August 1, 2012 (edited) My MPG's have dropped to 365 miles on a tank so upon checking when I'd last changed my air filter (49901 Wix) it became apparent that it was time again. Changed it, confident my MPG's would once again allow me 390-400 miles on a tank. Nope. Looked up the recommended spark plug change and see it's 90K, hmmm. I'm at 107K now so it's overdue. Called my local Ford dealer for an estimate ...................holy smoke! Parts/labor to change the plugs is a whopping $469 !!! How can this be? Oh yeah, if the plug breaks it's $65 each to remove the broken piece! It's a plain old spark plug. WTH is there to break? Called the Parts Dept back & asked the price of plugs. $15.50 each. SP448 (AGSF32YPC) Motorcraft at Rock Auto are $6.41 & $7.09 @ Advance Auto !! Mind blowing! Edited August 1, 2012 by ncranchero Quote Link to comment Share on other sites More sharing options...
Drifter Posted September 5, 2014 Share Posted September 5, 2014 it takes under 30 minutes to change these plugs. they are right on top. 8MM socket for the bolt that hold the coilpack on and a sparkplug socket to remove the plug. i bought the new Irdiumn pluga at Oriellys for under 6.00 each Quote Link to comment Share on other sites More sharing options...
2013TransitConnect Posted September 5, 2014 Share Posted September 5, 2014 I usually do plugs, points and rotor all at the same time. Don't forget the dealer leaves you little paper sheets on the floor as part of the $469. Quote Link to comment Share on other sites More sharing options...
Prairie Pyro Posted July 31, 2016 Share Posted July 31, 2016 On 9/5/2014 at 10:07 PM, 2013TransitConnect said: points and rotor all at the same time Expand ?, Transit is coil over plug system. Yes I see this is a old thread but just adding for others info. Quote Link to comment Share on other sites More sharing options...
