Mark Cooper Posted June 23, 2022 Share Posted June 23, 2022 My door sensor says the door isn't closed properly when it is and it can take up to 10 attempts before it accepts it's closed. ay ideas how I can stop it happening please? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted June 23, 2022 Share Posted June 23, 2022 The latch mechanism contains the switch the identifies the door status. You probably need to replace the latch assembly. Quote Link to comment Share on other sites More sharing options...
Willygee Posted June 24, 2022 Share Posted June 24, 2022 Does this require reprogramming of any sort? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted June 24, 2022 Share Posted June 24, 2022 2 hours ago, Willygee said: Does this require reprogramming of any sort? I'm pretty sure it does not. Nothing I have seen in the drawings or Forscan indicates this must be programmed or configured. But I have never replaced one. Quote Link to comment Share on other sites More sharing options...
Wingerr Posted December 8, 2022 Share Posted December 8, 2022 (edited) On 6/23/2022 at 9:23 AM, Mark Cooper said: My door sensor says the door isn't closed properly when it is and it can take up to 10 attempts before it accepts it's closed. ay ideas how I can stop it happening please? This is apparently a very common issue, so assuming they didn't redesign the assembly for higher reliability than the original, i'd refrain from going and buying another door latch assembly just to fix this. instead, you can just open up the door panel and locate the two wires that need to be connected to make it think the door is closed, and that'll take care of the inability to lock your doors. Edited December 8, 2022 by Wingerr Sp Quote Link to comment Share on other sites More sharing options...
TC281 Posted November 2, 2023 Share Posted November 2, 2023 On 12/8/2022 at 2:36 PM, Wingerr said: instead, you can just open up the door panel and locate the two wires that need to be connected to make it think the door is closed, and that'll take care of the inability to lock your doors. What 2 wires? Thank you. Quote Link to comment Share on other sites More sharing options...
ThatsMyDawg Posted November 10, 2023 Share Posted November 10, 2023 Like many I also have the door ajar issue. I prefer not to do any bypass, because I want to know if my door is really not properly shut. I am going to have Ford to a software update maybe this year or next. I have read that sometimes that fixes this and other small issues. Sometime you have to swap switches, sensor and harnesses though. Since I have LED lights inside it is super bright at night when the lights pop on when the door shows as open. (even if it is not) I hate that so while night driving I always turn the inside lights off. The door chime is also annoying, but with all the road noise, etc it's not the worse. Either way I will deal with the door ajar at some point, but for now there are bigger fish to fry. Quote Link to comment Share on other sites More sharing options...
braddd Posted January 30, 2025 Share Posted January 30, 2025 If you bypass the door it will no longer trigger your alarm if opened. Assuming you have an alarm... Quote Link to comment Share on other sites More sharing options...
