SavvyQueen Posted June 2, 2022 Share Posted June 2, 2022 Hi! My 2016 transit connect with LWB doesn’t have a 3rd row seat. Can used ones be added to make it a 7-passenger van? The pics below are the area I want to add seats. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted June 4, 2022 Share Posted June 4, 2022 If you can get the seats, I am sure that you can drill holes and bolt them in. Actually, you may already have the holes. Left the carpet kit and look. Installing the seat belts may be more difficult. But not really. You just have to have all the right parts. Then it's as simple as removing your parts, and installing the new parts. SavvyQueen 1 Quote Link to comment Share on other sites More sharing options...
SavvyQueen Posted June 4, 2022 Author Share Posted June 4, 2022 Thanks for that response. I’ve found used seats at a junk yard, now I need to find someone local who can install them correctly. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted June 5, 2022 Share Posted June 5, 2022 Does the junkyard have a complete van? The best thing to do is take photos. Lots of them. Photos of your van. Photos of that van at the junkyard. Compare what is different. As you may need things like the carpet kit, the interior panels, the seat belts (obviously). And if your van does not have an auxiliary junction box, and that van has it - then plan on taking that also. SavvyQueen 1 Quote Link to comment Share on other sites More sharing options...
SavvyQueen Posted June 6, 2022 Author Share Posted June 6, 2022 Thanks for that response. I’ve found used seats at a junk yard, now I need to find someone local who can install them correctly. Quote Link to comment Share on other sites More sharing options...
SavvyQueen Posted June 6, 2022 Author Share Posted June 6, 2022 On 6/4/2022 at 1:53 AM, Fifty150 said: If you can get the seats, I am sure that you can drill holes and bolt them in. Actually, you may already have the holes. Left the carpet kit and look. Installing the seat belts may be more difficult. But not really. You just have to have all the right parts. Then it's as simple as removing your parts, and installing the new parts. This info is so helpful. I do have a side panel box in the rear right area. As a matter of fact, I’m there’s a small fuse laying on the carpet beside it. And yes, the junkyard has the entire van. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted June 6, 2022 Share Posted June 6, 2022 Look at the photo. Right above the junction box, there is a seat belt. You will need that. And the body panels. For both sides. Quote Link to comment Share on other sites More sharing options...
NastyNate338 Posted May 29, 2025 Share Posted May 29, 2025 Hi - FNG here. 16 TC LWB Cargo, got a 2nd row in and now trying to add 3rd row. Do the cargo versions come with 3rd row threaded, seat mounting holes? I’ve got the deck lined w sound deadening material and trying to minimize the rework. Do thesevans have the holes and if so, anyone got pics of location and reference point? Quote Link to comment Share on other sites More sharing options...
windguy Posted May 29, 2025 Share Posted May 29, 2025 14 hours ago, NastyNate338 said: Hi - FNG here. 16 TC LWB Cargo, got a 2nd row in and now trying to add 3rd row. Do the cargo versions come with 3rd row threaded, seat mounting holes? I’ve got the deck lined w sound deadening material and trying to minimize the rework. Do thesevans have the holes and if so, anyone got pics of location and reference point? Welcome to the forum. I don't ever recall anyone adding a 3rd row seat to a cargo van. Just 2nd row. I don't think the holes exist. The reason the 2nd row holes were there plus seat belt provisions was the vans were imported with 2nd row seats to get around the chicken tax. Seats and belts, windows, etc were then stripped out to make it a cargo van. I too added sound proofing but I have a pic with the cargo mat removed if that helps. Good luck! Quote Link to comment Share on other sites More sharing options...
NastyNate338 Posted May 29, 2025 Share Posted May 29, 2025 47 minutes ago, windguy said: Welcome to the forum. I don't ever recall anyone adding a 3rd row seat to a cargo van. Just 2nd row. I don't think the holes exist. The reason the 2nd row holes were there plus seat belt provisions was the vans were imported with 2nd row seats to get around the chicken tax. Seats and belts, windows, etc were then stripped out to make it a cargo van. I too added sound proofing but I have a pic with the cargo mat removed if that helps. Good luck! I think you’re right. I placed the seats where it would make sense and then scraped up all the sound deadening material in the surrounding area and didn’t find mounting holes. I’m gonna go to Ford and print a diagram that details the difference between the two vans. It should just be a threaded nut that’s machined into the body. Dependent upon what I find out, I might fan some brackets and drill some holes but we’ll see. Thanks for the reply🤙🏽 Quote Link to comment Share on other sites More sharing options...
