i86hotdogs Posted March 22, 2022 Share Posted March 22, 2022 Forgive me for the sporatic questions, I pulled a P0113 code on my 2016 TC with the 2.5. Is the IAT sensor integrated in the MAF sensor located on the airbox? I only ask because there are only 4 wires going to the MAF connector. On most MAF sensors with the IAT integrated, there are 6 wires going to it. I replaced the MAF sensor back in January to correct a MAF sensor code. So the sensor is fairly new, and I've only put a few hundred miles on it since. I did notice some fraying on the light purlple with dark purple striped wire. So that may be the root cause as well. I just want to confirm before I do some wiring. I haven't been able to find any diagrams for this piece. Knowing which wires go to what would be beneficial. I bought a Motorcraft wiring kit yesterday, and just my luck: the connector does not fit on the MAF sensor. There are hundreds of these wires in the junkyard, from similar Fords: Focus, Fusion, Escape, etc. But all of them have 6 wires going to them, and only two wires match in color: yellow with purple stripe and light purple with dark purple stripe. Any direction would be greatly appreciated in this. The van runs, but will struggle to start when cold. And I know the van will run lean with this code active, so I'm trying to fix the issue ASAP as possible. Thanks all! Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted March 23, 2022 Share Posted March 23, 2022 Here's the wiring diagram. maf.pdfFetching info... i86hotdogs and windguy 1 1 Quote Link to comment Share on other sites More sharing options...
i86hotdogs Posted March 23, 2022 Author Share Posted March 23, 2022 Don, you're a saint for this. As suspected, the purple wire is the IAT wire, and that's what was frayed. I took the pigtail from the fusion at the junkyard and wired it up with no issue. Thanks again for the help! Quote Link to comment Share on other sites More sharing options...
