Boutique Blinds Posted January 23, 2022 Share Posted January 23, 2022 I have a 2012 TC and it is chewing through front tires like crazy. It's been for 2 alignments and the shop says it's within spec. The van is pulling to the right and the passenger front tire is the worst with the majority of the wear on the outside. The front driver side also has the majority of the wear on the outside, but is not as significant as the passenger side tire. The back tires are like new! Any help would be greatly appreciated! TIA Quote Link to comment Share on other sites More sharing options...
BSJBSJ Posted January 23, 2022 Share Posted January 23, 2022 Take it to a different shop? Quote Link to comment Share on other sites More sharing options...
Gideon Posted January 26, 2022 Share Posted January 26, 2022 Could it be suspension, not alignment, problems ?? Weak springs perhaps? IMHO (and I'm no mechanic), if springs are weak and van leans more than usual in turns, that may be the reason. Quote Link to comment Share on other sites More sharing options...
G B L Posted February 4, 2022 Share Posted February 4, 2022 If it pulls to the right then the Passenger side tire is holding line and is scrubbing. The out side of the front tires will wear more if the cornering is aggressive . If the car is sitting level and evenly loaded you should find a shop that can do an accurate toe in adjustment , one with a good scrub gauge would be the best. Quote Link to comment Share on other sites More sharing options...
