francie15 Posted October 25, 2020 Share Posted October 25, 2020 Hello, first winter storm in Western Colorado. I'm sure this info is somewhere but I'm cold and grumpy. In my house now but my van stuck at the bottom of my street. I've never had traction control and I only just got the van a few months ago. When it was icy on the highway, I see how it stopped from sliding into a ditch but it also made it so I was sideways and someone could have run into me. It freaked me out. I'm looking in the manual and it says to turn it off on the instrument panel but I can't figure it out. Help is appreciated Quote Link to comment Share on other sites More sharing options...
G B L Posted October 26, 2020 Share Posted October 26, 2020 If it is a Gen 2 use the steering wheel switch to go into the menu and shut it off , you will have to do this every time you start the car. I shut mine off all the time. It is not so easy on the Gen 1, I think you have to pull the ABS fuse. francie15 1 Quote Link to comment Share on other sites More sharing options...
jrm223 Posted October 26, 2020 Share Posted October 26, 2020 On my 2015 XL cargo, there's a traction control button on the center dash right in front of the base of the shifter, slightly to the right. Tap it once to turn off traction control and then again when you want to turn traction control back on. As G B L mentioned, it resets when you shut off the engine, so it will automatically be back on again next time you start the van. Quote Link to comment Share on other sites More sharing options...
G B L Posted October 28, 2020 Share Posted October 28, 2020 On 10/26/2020 at 8:53 PM, jrm223 said: there's a traction control button on the center dash right in front of the base of the shifter, slightly to the right Expand That is one reason I would wish for a 2015 that would be great! Quote Link to comment Share on other sites More sharing options...
francie15 Posted October 28, 2020 Author Share Posted October 28, 2020 On 10/26/2020 at 12:06 PM, G B L said: If it is a Gen 2 use the steering wheel switch to go into the menu and shut it off , you will have to do this every time you start the car. I shut mine off all the time. It is not so easy on the Gen 1, I think you have to pull the ABS fuse. Expand Thank you, I didn't know if it was Gen 2 or 1, but I did eventually find it in the menu. Not intuitive at all. Appreciate the help! Quote Link to comment Share on other sites More sharing options...
