sebestyen13 Posted September 27, 2020 Share Posted September 27, 2020 I have a 2019 with cargo doors. There are 2 interior lights in the back on the sides. If the vehicle is on and the cargo doors are open they stay on. I can switch off the other overhead lamps, but can't figure out how to turn those off in that scenario. Id like to have the doors open and the music on in the dark. Quote Link to comment Share on other sites More sharing options...
jrm223 Posted September 28, 2020 Share Posted September 28, 2020 My solution for the single cargo light in my 2015 was to remove the light completely. Instead, I use a couple magnet flashlights, so I can move them around and even use them outside the van, as needed. Quote Link to comment Share on other sites More sharing options...
desert_connect Posted September 28, 2020 Share Posted September 28, 2020 My stock cargo light was in the wrong spot for me and the van computer shut it off 10 minutes after shutting the ignition off. I removed it completely and added two small RV style LED lights hard wired into the rear 12v outlet so I now can turn them on or off independently without interference from the van computer. I also added 2 magnetic hanging rechargeable lights that can be moved about similar to jrm223. You can see them in my thread here; Quote Link to comment Share on other sites More sharing options...
