Rear window washers
  • 1 year later...
I'm sure I'm missing something in the manual, but I can't figure out where you find the reservoirs for the rear window washers. Thanks for any help.
I suspect it uses the same tank as the front, which is too small. I didn't see anything in the manual.
I just stumbled across the over-drive cut off switch under the gear shift knob!
I also bought a tow bar, a Drawtight,. It fits nicely. Cost 316 all installed.
Washer System
The windshield washer system consists of the washer reservoir and washer pump. When WASH is selected on the wiper/washer switch, the wiper/washer switch grounds the washer pump to direct fluid to the windshield glass. When the washer system is activated, the GEM will cycle the wipers several times to clear the window glass of any remaining fluid. If equipped with rear wipers, the washer pump reverses polarity to direct fluid to the rear door glass.
  • 7 months later...
The wiper fluid tank you see under the hood is not the full size of the tank. It passes through the sheetmetal into an area inside the fender. The actual tank is quite large.
