Denis Ryan Posted June 26, 2020 Share Posted June 26, 2020 (edited) I have a 2015 TC. I changed out the cabin filter about month ago because the blower fan was making a lot of noise on 3 or 4. When I took the old filter out, it was ripped to shreds and it took a long time to clean out all of the debris (mostly insulation) from the fan and filter slot. I installed a new carbon filter. Recently the noise started up again, so I pulled out the new filter (which was still intact) and again found lots of debris, this time mostly plastic with a little bit of insulation (pic attached). It's like the fan is sucking in and shredding insulation from somewhere? Anyone ever heard of or experienced a problem like this before? Blower fan debris.HEIC Edited June 26, 2020 by Denis Ryan Forgot to add picture Quote Link to comment Share on other sites More sharing options...
desert_connect Posted June 27, 2020 Share Posted June 27, 2020 19 hours ago, Denis Ryan said: I have a 2015 TC. I changed out the cabin filter about month ago because the blower fan was making a lot of noise on 3 or 4. When I took the old filter out, it was ripped to shreds and it took a long time to clean out all of the debris (mostly insulation) from the fan and filter slot. I installed a new carbon filter. Recently the noise started up again, so I pulled out the new filter (which was still intact) and again found lots of debris, this time mostly plastic with a little bit of insulation (pic attached). It's like the fan is sucking in and shredding insulation from somewhere? Anyone ever heard of or experienced a problem like this before? Blower fan debris.HEIC I had a similar problem and it was two mice. You can read all about it here: Quote Link to comment Share on other sites More sharing options...
Denis Ryan Posted June 27, 2020 Author Share Posted June 27, 2020 Awesome....... By the way the debris is torn up, mice is exactly what it is. Never would have thought of that, so thank you so much for the reply. You just saved me a ton of money taking it in to the shop for them to go on an endless search looking for a cause. We have chickens and I've seen the mice in their coop. Normally I park the car in front of the garage - guess I'm going to have to give that a good clean up so I can use it for what it was intended for instead of a workshop! Quote Link to comment Share on other sites More sharing options...
G B L Posted July 3, 2020 Share Posted July 3, 2020 On 6/27/2020 at 11:32 AM, Denis Ryan said: guess I'm going to have to give that a good clean up so I can use it for what it was intended for instead of a workshop! For me the work shop is more important, I use a CAT! Quote Link to comment Share on other sites More sharing options...
