Parasitic draw (couldn’t find the proper topic forum)
I have a parasitic loss somewhere. I did the multimeter test and only had .003 showing so I know that’s not enough to kill the battery after 2 min use days
Alternator I’m assuming at this point although I’ve had no charging issues, I heard the diodes get bad in these
anyone else been here? What about the wiring to the alternator that I’ve heard of as Well
Thanks
If the draw is 3 milli amps then yeah you probably dont have a parasitic draw.  How did you perform this test?
Dont overlook a bad battery, whats the voltage 20 minutes after you shut the engine off?  A dead or shorted cell sometimes have you thinking the battery is ok but it will never start after sitting a few minutes
With All the modules in the  TC there is definitely a draw on the battery.  The fact that you have to reset the radio and the clock if you disconnect the bat tells you that.
If you have a dead or shorted  cell will definitely have an effect on  the voltage , the sitting voltage will be low and the charging voltage will be hi.
  • 2 years later...
