robertmcclain Posted December 24, 2011 Share Posted December 24, 2011 The window washer tubing on the driver's side of my 2011 XLT is clogged or kinked. The passenger side works ok. I removed the tube where it enters the wiper and there is only a weak drip when I activate the washer. So I conclude my problem is upstream. My Ford dealer provided a parts diagram that shows there is a "T" in the tubing, but no clue where it is located. I suspect it is somewhere near the jack storage. Does anyone know there the "T" is located and how to get to it? Thanks Quote Link to comment Share on other sites More sharing options...
Mikeeshaq Posted December 24, 2011 Share Posted December 24, 2011 Check behind the tail lamp assembly, that is where everything goes into the umbilicle Quote Link to comment Share on other sites More sharing options...
Mikeeshaq Posted December 24, 2011 Share Posted December 24, 2011 I looked at my 2010 Ford TC Workshop Manual and it gives no clue how the tubing is routed Quote Link to comment Share on other sites More sharing options...
robertmcclain Posted December 27, 2011 Author Share Posted December 27, 2011 Check behind the tail lamp assembly, that is where everything goes into the umbilicle You were right on! Removed the taillight and the hose with two kinks was in the open. I straightened them out and the washers work fine. Thanks. That's what this forum is all about. robertlane 1 Quote Link to comment Share on other sites More sharing options...
Willie Posted December 28, 2011 Share Posted December 28, 2011 I'm impressed, Mike! Or did you two guys set this up???? Quote Link to comment Share on other sites More sharing options...
PapillonHeroes Posted April 9, 2013 Share Posted April 9, 2013 Removed the taillight and the hose with two kinks was in the open. Quote Link to comment Share on other sites More sharing options...
