govandlaw 1 Posted January 6, 2019 (edited) Anyone finding the mid-row power outlet very unreliable? Wonder if there is an easy fix (like an upgraded inverter feeding the stock outlet) to lengthen how long the outlet actually works before the safety faught (flashing green lights) triggers, even with low wattage items, I only get a few minutes before it stops working. Edited January 6, 2019 by govandlaw 1 Marquizzo reacted to this Share this post Link to post Share on other sites
Fifty150 313 Posted January 6, 2019 I haven't had a problem with mine. Share this post Link to post Share on other sites
Tbaptist 1 Posted February 21, 2020 On 1/5/2019 at 7:11 PM, govandlaw said: Anyone finding the mid-row power outlet very unreliable? Wonder if there is an easy fix (like an upgraded inverter feeding the stock outlet) to lengthen how long the outlet actually works before the safety faught (flashing green lights) triggers, even with low wattage items, I only get a few minutes before it stops working. I am having problem with my built in inverter on my 2019 TC XLT. Only trying to power an Echo Dot. Measured voltage is about 83volts not 110. It turns off after a few min. 1 Marquizzo reacted to this Share this post Link to post Share on other sites
Tom c 1 Posted June 8, 2020 Mine works for 15 mins then shuts off. Turn car off and back on works for 15 mins and stops again. I have had it to the dealer 3 times. 1 Marquizzo reacted to this Share this post Link to post Share on other sites
Marquizzo 4 Posted July 13, 2020 Hey @Tom c what did the dealer end up doing to fix it? I'm having the same problem with mine. We get 10-15 minutes of power before it shuts off. I have to pull over in the freeway, fully take the key out of the ignition, open the driver door to turn off the electronics, and then turn the car back on to get power out of the outlet. Was the dealership finally able to fix it for you? Share this post Link to post Share on other sites
Nico 0 Posted July 17, 2020 Hi There, I had the same issue with my new 2019 TC Limited (I'm in the UK). The dealer had my vehicle back 3 times. After giving the dealer a detailed explanation of the problem and a possible suggestion, the workshop couldn't find a problem! When I collected the vehicle I asked what tests did they carry out. It turned out the technician tested the inverter with an iPhone charger and for only 10mins. The second dealer visit I left in the van for testing a desk lamp with an LED bulb and clear instructions to keep testing beyond 15 minutes. The third visit to remedy the issue was to reload the vehicle software. Since then all has been working just fine. Share this post Link to post Share on other sites
Marquizzo 4 Posted August 25, 2020 (edited) @Nico So reloading the vehicle software was the solution? What software specifically was reloaded? Was it the Sync3 software, or some other kind of onboard computer? I'd like to get specifics so I can ask my dealership to do the same. Thanks! Edited August 25, 2020 by Marquizzo Share this post Link to post Share on other sites
