Avnut Posted October 8, 2018 Share Posted October 8, 2018 Some pass along information. My '14 SWB with the 2.5L has around 55,000 miles now and I want to check the condition of the plugs and just break them free. I don't want to wait till a 100,000 miles before doing so. I went to one of the local Ford dealers and asked for the spark plug torque specs. For a 2.5L the spark plugs should be torqued to 106 inch pounds or 8.83 foot pounds. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted October 8, 2018 Share Posted October 8, 2018 How did the plugs look at 55,000 miles? Did you put the same plugs back into the engine, or replace them with new since you had them out? Quote Link to comment Share on other sites More sharing options...
Avnut Posted October 8, 2018 Author Share Posted October 8, 2018 I'm looking to pull them between now and the end of October. I have to work it into my around the house project schedule. I plan on replacing the plugs since I'll have them out. Quote Link to comment Share on other sites More sharing options...
G B L Posted October 8, 2018 Share Posted October 8, 2018 Had mine out at 50000 Plus miles . The main reason was to Never seize the thread. They were is good condition, will replace at about 80000. They are taper seat , 1/16 of a turn after tight will be good. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted January 7, 2019 Share Posted January 7, 2019 On 10/7/2018 at 7:00 PM, Avnut said: For a 2.5L the spark plugs should be torqued to 106 inch pounds or 8.83 foot pounds. On 10/8/2018 at 5:43 AM, G B L said: 1/16 of a turn after tight will be good. Sounds about right. I've heard 9 ft lbs. I've heard "just a little past tight". Which plugs are you guys using? Common wisdom was that with Ford engines, you are suppose to use OEM Ford MotorCraft parts only. For whatever reason, most people insist that any other brand of parts, and you will have problems. Coils, wires, plugs..... Then you get the guys who insist on using only "performance part" brands. I just exchanged the plugs, wires, and ignition coil on my truck after owning it for 12 years. I went with economy. $0.88 spark plugs from E3. $16 Autolite wires. $75 MSD ignition coil. In theory, the E3 is a performance part. OEM Ford MotorCraft spark plug wires are 7mm, and the Autolite wires are 8mm. The OEM ignition coil was about $50 more than the MSD. I don't believe much in superstition. Truck fires right up and runs fine. No issues. All parts are supposedly "upgrade" parts, even though I got them for less money. So now I'm wondering about Transit Connect tune-up parts. I guess the wires and coils do not need to be replaced unless there is visible, unacceptable wear, or you're experiencing misfires. Has anyone tried other brands of spark plugs, coils, in their Transit Connect? NGK, Denso, MSD, Bosch, Champion? Quote Link to comment Share on other sites More sharing options...
G B L Posted January 8, 2019 Share Posted January 8, 2019 With coil on plug there is not much that goes . Just check for corrosion in the coil socket when you change them, i must be getting old but now I think I did use Motorcraft with the best Electrode, but I am not 100 percent sure. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted January 8, 2019 Share Posted January 8, 2019 From my recollection, MotorCraft plugs are not platinum or iridium. What I also recall is that Denso is OEM for MotorCraft. So far, the E3 work. I can't say that there's any gain in performance or mileage, which is claimed in advertising. And E3 spends quite a bit on promotion. But they work. I would buy it again for the right price. I would not spend more for them. Quote Link to comment Share on other sites More sharing options...
