lowpt2001 Posted April 12, 2018 Share Posted April 12, 2018 I was just coming home and my transmission failed on me. When starting up a hill in 3rd gear, it downshifted but only revved. I lost forward movement. Since I was coming home, mostly downhill, i made it to the top of this Crest and stopped. It didn't move on it's own. I coasted downhill to get it started. When I got it fast enough for 3rd it would move. The low gears seemed gone. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted April 12, 2018 Share Posted April 12, 2018 This has the symptoms of "limp" mode. Did you get a fault message? When there is a serious fault condition, the transmission goes into a high gear and the engine revs are limited. Cycling power may fix it if the cause was a temporary bad sensor reading. You need to read the DTC (not just the check engine) codes to see what happened. Quote Link to comment Share on other sites More sharing options...
lowpt2001 Posted April 13, 2018 Author Share Posted April 13, 2018 Is there a way to pull the CV codes on these Van's without a reader/scanner? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted April 13, 2018 Share Posted April 13, 2018 No, diagnostic trouble codes (DTC) can only be read with a scanner or reader. The free program Forscan with an OBD2 adapter works. Quote Link to comment Share on other sites More sharing options...
G B L Posted April 14, 2018 Share Posted April 14, 2018 You Need a scanner for sure. The first thing to do is check the fluid level. what year , how many miles? Quote Link to comment Share on other sites More sharing options...
