MLB Posted March 17, 2018 Share Posted March 17, 2018 Double DIN installed and got it back with time and date correct but after the battery died I lost the setup and the double din install loses the buttons to set the time/date. There are no steering wheel controls. Any other way to access the settings or should I find a nice picture to mount there as I planned? Quote Link to comment Share on other sites More sharing options...
Beta Don Posted March 17, 2018 Share Posted March 17, 2018 You're not very clear, but I'm guessing what you're describing is the same thing I have I installed a double DIN Pioneer Nav receiver and kept the small OEM upper screen for the back-up camera. It also shows the time, date and outside temperature. If you disconnect the battery, the time and date reset and you're stuck looking at the wrong numbers Right? What I do is . . . . I carry the original radio panel with the buttons in the glovebox. I pull the double DIN faceplate off and plug the OEM panel back in and then I can reset the time and date. Unplug it, put the double DIN faceplate back in place and everything's good . . . . until the next time I disconnect the battery Don Quote Link to comment Share on other sites More sharing options...
JoeMan Posted March 18, 2018 Share Posted March 18, 2018 Yep, Same here except I don't bother with the time reset and I don't have the factory backup camera. I just have the camera I installed and it displays on the new nav unit. The old screen just displays temp and I cover the other stuff with black tape. Was thinking about a nice pic though. Quote Link to comment Share on other sites More sharing options...
