Gen 2 Wiring Schematic
I feel like a panhandler.  But here goes.  Does anyone have a service manual which shows the lighting wiring diagram, and points of access?  In my pickup, when I open the passenger side kick panels, I can access the fuse box, and all of the wiring which makes it real easy for me to splice into the OEM lighting.  So I'm trying to find an easy shortcut to wire in strobe flashers into the marker lights.   The unit that I'm installing simply taps into the positive and negative wires anywhere along the wire run.  Then if it's under the dash or behind the glove box, it would be really simple to add a toggle switch to trigger the flasher.
Edited by Fifty150
