Welshdean Posted May 13, 2016 Share Posted May 13, 2016 I've recently bought a van and it has got one of those red plastic isolator keys that you have to put into the connection at the front of the bonnet in order to open the doors and also be able to start the vehicle. It's a pain in the arse and I would like to get rid of it. What would I need to do to get rid of it and have the vehicle working off the fob and key ? Am I likely to encounter any problems if it's removed as I'm wondering if they've put it on there in the past to fix an issue of some sort ? Thanks Quote Link to comment Share on other sites More sharing options...
mrtn Posted May 13, 2016 Share Posted May 13, 2016 First time hearing about something like this. Time for this: Quote Link to comment Share on other sites More sharing options...
Welshdean Posted May 13, 2016 Author Share Posted May 13, 2016 I don't know how to put pictures up on here but if you type into Google... Van isolator key, you will see what I mean. It's a weird shape and red. Quote Link to comment Share on other sites More sharing options...
mrtn Posted May 13, 2016 Share Posted May 13, 2016 This looks like a ground switch. You should be able to bypass it. Do you have a standard Ford key for ignition? Quote Link to comment Share on other sites More sharing options...
BSUPC Posted May 14, 2016 Share Posted May 14, 2016 Was the van part of a fleet for a company ? I ask this because from what I am seeing on google and what you are describing, this is a battery cutoff switch like they use in emergency vehicles. I know all of our firetrucks had them installed in the floor right beside the drivers seat. It is used to isolate all of the equipment from the battery while the vehicle is parked between calls so that the battery does not get drained. If this is the case, then you should just be able to trace the wires, remove the switch, and connect straight back to the battery. Quote Link to comment Share on other sites More sharing options...
