What is this?
I'm not sure I know what your referring too. Can you provide a picture?
Your not referring to the back up sensors located just behind the passenger wheel well are you?
Edited by Booner
There are Impact sensors on both sides of the Sliders one in the B pillar and the other about 3to4 inches behind the slider door. I don't think that you would want to move them.
There is also a latch that will not let you open the right slider if you have the fuel door open.
Yes it is in the right place and the component diagram has only one thing in the harness there behind the slider.
If it is the right side of the car there is another module above the impact sensor and that is the fuel pump control module
I am not sure what impact moving it would have
Cheers
Edited by G B L
