Campcrazy Posted February 28, 2016 Share Posted February 28, 2016 I found it odd that in addition to defrost settings on the vent selection dial that there is also one at the highest heat setting of the temperature dial. So reading the manual it says that it has a heated windshield switch...but they show a switch and not it on the temperature dial. So is it heated? And if not then what purpose is this furthest right icon on the temperature dial? I do have rear defrost and heated mirrors but they're both on a separate switch above radio. Quote Link to comment Share on other sites More sharing options...
BSUPC Posted February 28, 2016 Share Posted February 28, 2016 (edited) The dealer told me on both of my 2012's that the switches both had to be in the defrost positions for the defroster to work. But I have had great success defrosting mine with just the selector switch in defrost and the fan selector not. Which of course this is the same dealer that spent 30 minutes trying to figure out how to pop the hood to show me the engine. Sad when the customer has to do their job and open the hood out of pity. But none the less, that is the explanation I was given on the dual defrost emblems. Edited February 28, 2016 by BSUPC LostInTransit 1 Quote Link to comment Share on other sites More sharing options...
103west43rd Posted February 28, 2016 Share Posted February 28, 2016 (edited) Hello Campcrazy, as per the owners manual for the 2010 Transit Connect (most of which should be the same as your 2013) here is the explanation for the defroster symbol on the fan switch........ Fan speed adjustment: Controls the volume of air circulated in the vehicle. For optimum defrosting performance, set the dial to at leastthe 3 or 4 position near the (defrost) symbol. Edited February 29, 2016 by 103west43rd Quote Link to comment Share on other sites More sharing options...
mrtn Posted February 29, 2016 Share Posted February 29, 2016 So is it heated? You can see the heating wires in the windshield if you look closely. Or check if you have the left button in the top right corner: http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/0jYAAOSwoydWsKMo/$/$_57.JPG It switches on the heater. Very unlikely tho, we have just had a topic here where it became apparent that you only got the windshield heater with Gen2. Quote Link to comment Share on other sites More sharing options...
