Dim Headlights
When our running lights are on, the headlights burn at proper intensity. But when you actually turn the lights on, so that the taillights will come on, the headlights get very dim. I have replaced the headlight switch, but apparently this wasn't the problem. Has anyone else had this problem and have a resolution?
Thanks!!!
It should be the other way around. The DRL should be running at some 60% intensity for saving the halogens and only getting full power when switched on manually. Probably something wrong with the relay. Check the book for the correct relay and try reinserting it first. Perhaps it's just a bad connection.
