towing a Transit
The answer seems to be NO according to the second gen owners manual Pg 159:
QUOTE (with bold added):
Recreational Vehicle Towing
Note: Put your climate control system in recirculated air mode to prevent exhaust fumes from entering the vehicle. See Climate Control (page 95).
Follow these guidelines if you have a need for recreational (RV) towing. An example of recreational towing would be towing your vehicle behind a motorhome. We designed these guidelines to prevent damage to your transmission.
Front-wheel drive vehicles CANNOT be flat-towed (all wheels on the ground), as transmission damage may occur. You can tow your vehicle with the front wheels off the ground by using a tow dolly. If you are using a tow dolly, follow the instructions specified by the equipment provider.
Edited by DonShockley
