RidingDonkeys Posted March 7, 2015 Share Posted March 7, 2015 OK we've seen a long list of owners who paid for a rear climate control that doesn't work. But is there anyone out there that can verify that their rear heat actually works? Quote Link to comment Share on other sites More sharing options...
G B L Posted March 23, 2015 Share Posted March 23, 2015 I did a test run with the car this morning . The starting temp outside was 10degrees F.Set the front heater on fan speed 3 and temp control high, and the air flow valve pointing to the feet . The rear fan was on 2 and the tempcontrol on high after a ten minute run the heat coming out of the B pillar vent was goodI also found that the vent hook up on the passinger side under the seat might not be good . when it ison the duct correctly then there is good heat for the passingers feet.The Rear heater gets most of the warm air from the front heater supplied through the duct.Hope this helps some one. Quote Link to comment Share on other sites More sharing options...
