tjump Posted June 29, 2010 Share Posted June 29, 2010 Alright so i ordered a JVC cd player just to get something a little better than what is in there. Came with the four DIN tools to get it out, put all four in all four snapped pulled and nothing doesn't go anywhere. Took it to Ford and they could only get 1 of them to dis-engag.. So i guess my question how do you take dash apart and sites or ways to start!? Quote Link to comment Share on other sites More sharing options...
JWWOODY Posted June 30, 2010 Share Posted June 30, 2010 I CHECKED THE SERVICE MANUAL AND THERE IS NO INFO ON THE RADIO REMOVAL. IT DOES SHOW THE DASH PANELS AS BEING REMOVABLE. THE FASCIA AROUND THE RADIO HAS TWO SCREWS ON EACH SIDE OF THE RADIO(PROBABLY BEHIND THE RADIO) AND 4 SNAP CLIPS ONE IN EACH CORNER. REMOVE THE SCREWS AND POP THE FASCIA OFF. THE STORAGE PANEL ABOVE THE RADIO IS HELD ON WITH ABOUT 8 SNAP CLIPS NO SCREWS. WOODY Quote Link to comment Share on other sites More sharing options...
tone007 Posted June 30, 2010 Share Posted June 30, 2010 The 4 tools are what you need, I ended up pulling my headrests out and sticking the bars through the loops in the tools and going nuts on them, left, right, pulling and pushing. It eventually came out. Quote Link to comment Share on other sites More sharing options...
tjump Posted June 30, 2010 Author Share Posted June 30, 2010 so tried all that those two screws are behind radio and cannot get to them. Iam giving up company truck and now its a little scraped up boss probably gonna kill me Unless somebody knows a better way Quote Link to comment Share on other sites More sharing options...
rooney2oons Posted July 10, 2010 Share Posted July 10, 2010 keep trying. the four removal keys do work. they have to go in the correct direction and you have to kinda move them toward the doors to press the retaining clip on the factory radio in. I had to do one side at a time. and it hurt my fingers too. Quote Link to comment Share on other sites More sharing options...
4DThinker Posted July 15, 2010 Share Posted July 15, 2010 I had trouble at first. The points on the end of the keys need to be pointed inward when inserted. It helps to angle them toward the outside a little as they go in. They need to wedge a spring loaded hook toward the inside unitl they hook over it. You should feel/hear them snap over the ends when inserted enough. Then there should be about 1 inch of the shaft still out before handles when they won't come out. Once hooked in all four corners, it helps to drop a long screwdriver down though both keys on a side. I used two screwdrivers, one for each side. Grab the shafts of each, then angle the keys a little toward the outside and pull. The keys are holding sprung retainers inward to allow the head unit to come out. All four need to be engaged at the same time. It is all much easier to understand when you have the head unit out. Once it's out you can manually depress the retainers to release and remove the keys one at a time. Hope that helps. 4D Quote Link to comment Share on other sites More sharing options...
tjump Posted July 15, 2010 Author Share Posted July 15, 2010 alrighty finally got the radio out now going on from this point. I didn't get a harness with the New stereo soooo does anybody know whats the colors are so i can just hard wire new one in or where i can get a wire harness that fits the transit ( place where i got new stereo didn't have the harness) Quote Link to comment Share on other sites More sharing options...
rlschow Posted July 20, 2010 Share Posted July 20, 2010 Scosche Unless you already got one, you'll want a dash kit as well as the harness. I bought them all as a package here because the price was right. They shipped it immediately. Quote Link to comment Share on other sites More sharing options...
danickstr Posted August 12, 2010 Share Posted August 12, 2010 the points on the removal tools should be pointed OUT according to my success. You hook the little tab and as you pull the keys toward the doors (outward) the tabs are levered inwards to free the unit. Other than that, the post above is very good and well-written info. Quote Link to comment Share on other sites More sharing options...
