Rear Seats (remove easily????)
Can the rear seats come out and be put back in easily? And can I choose which side the single seat is on (probably not)? I need to use the vehicle for BOTH personal and work use. I'm thinking about buying one as a film and video production van. I think I will need at least one window in the back so a back seat passenger has a window to look out; if the other side is windowless I can put shelves up. And will the "slots" (where it connects to the floor) for the back seat pose any problems when the seat is out?
What other major differences are there between the cargo van (which is windowless) and the wagon (which has windows).
Thanks for responding.
The seats come out easily. You will need a Torx wrench. Afterwards the slots and bolt holes for the backseats will be recessed into the flat floor. You will still have the rear foot well, rather than a completely flat floor all the way to the front seat. If that is a problem, I think it could be easily fixed with a small piece of plywood.
  • 4 months later...
Is it possible to pull out just 2 of the 3 seats back there? Thanks.
THE DOUBLE SEAT ON THE LEFT CAN COME OUT LEAVIING THE SINGLE, OR THE SINGLE CAN COME OUT AND LEAVE THE DOUBLE. JUST PUT THE BOLTS BACK INTO THE FLOOR HOLES TO KEEP DIRT OUT.
WOODY
