NastyNate338 Posted 3 hours ago Share Posted 3 hours ago (edited) Got a funky one for you guys. This past Monday, I’m sitting in Van, idling w AC on, closing out a work order when Van dies. I turned ignition off then tried to restart it and a “parking aid malfunction” message accompanied by a “starting system fault” appeared on the dash. Checked all fuses = GOOD tested battery = GOOD inspected backup sensors, harness and connectors for corrosion, connection etc = GOOD Visually inspected wiring at PAM in cargo area = GOOD I disconnected battery to force a reset of the PAM and to clear any faults and then I was able to start it again. 45 min later at a stop light, it did it again and this was also resolved by DC the battery for 5 min. I bought a BT OBDII adapter and downloaded FORScan and tried to unsuccessfully recreate the fault so I could pull a DTC. It only happens when I’m parked and once while moving. I just have to wait til it happens and each time it’s reoccurred, FORScan is unable to pull DTCs off the PAM. I can reboot the PAM with FORScan now and start the van vs DC the battery so at least I have that going for me. When fault is active, it seems to trigger the anti theft because I can’t shift into neutral, roll down windows, nothing. I’ve disconnected the PAM for the time being and the van starts but I get the “parking aid fault service required” message. I’m thinking the PAM itself is hosed but don’t know how to test to verify before I drop $200 on a new one. I’m thinking if it was a sensor FORScan would spit a DTC that’s related to a sensor. Anyone know how to test a PAM? Anyone have any other ideas that I may be missing? Attached is a screenshot of the logs when the fault is active. Thanks in advance guys🤙🏽 Edited 3 hours ago by NastyNate338 Forgot something Quote Link to comment Share on other sites More sharing options...
