BSJBSJ Posted February 12 Share Posted February 12 Snow and ice has knocked my wipers out of time. How do I reset them? I can move them to full vertical on the windshield. Turn on the ignition and it stows them properly. Hit the lever again and the almost go back to vertical. Next actuation they go less than before. Less each time till they cross each other and jam about a foot from horizontal. Quote Link to comment Share on other sites More sharing options...
JackGrimshaw Posted February 12 Share Posted February 12 (edited) First thing I would check is are they loose on the posts or are the arms or posts stripped. Do you have to pull one off to reset? Edited February 12 by JackGrimshaw Quote Link to comment Share on other sites More sharing options...
G B L Posted February 13 Share Posted February 13 If the wiper arms are tight on the posts , then you will need to go through the timing procedure. A good scan tool will make this easy. Quote Link to comment Share on other sites More sharing options...
the--drew Posted February 17 Share Posted February 17 I just did it recently with forscan. Quote Link to comment Share on other sites More sharing options...
