drum_buster Posted January 13 Share Posted January 13 Looking for anyone that has experience or confirmation of changing the tire size settings in a Gen1 Transit connect. Specifically a 2013, US version. I understand it should be in theory possible with the lastest forscan software with custom circumference, but I have only read about other users successful doing so within the context of the later year TCs. Thanks, Quote Link to comment Share on other sites More sharing options...
drum_buster Posted August 7 Author Share Posted August 7 Still searching for answers here: If anyone in UK has a gen 1 Transit Connect or Tourneo, and can use forscan to send me a screenshot of your IC, VSM, and GEM As Built, as well as your factory tire size, that would be appreciated. I'm having AI reverse engineer to identify if any of these as built data corresponds. Quote Link to comment Share on other sites More sharing options...
windguy Posted August 9 Share Posted August 9 @drum_buster Just some random thoughts to help get your question answered. Have you tried posting your question on the FORSCAN forum? I have a Gen2 TC. I'm vaguely aware that the TC shares some similarities to the Ford Focus. Not sure about the Gen1 TC, but perhaps that too is similar to the Focus or another Ford model. If so, perhaps there's a Focus forum you can post your question on as well. Keep us posted. Good luck! Quote Link to comment Share on other sites More sharing options...
drum_buster Posted August 11 Author Share Posted August 11 (edited) @windguy Great suggestions, I have not gotten that far due to time. I do have some clues - and i'll share an abridged update on findings thus far: I am going to be painfully clear on van model/etc for clarity for all future readers Gen2 TC is somehwat well documented elsewhere in this forum and Forscan forums on selecting/modifying screen menues as well as manual modificatino of as-built wheel size data. I've read extensively on that. I've used Forscan on my Gen1, there is no immediate tire size selection. Further, as as far as I can tell, As-built data is not revealing any obviuos lines of hex data that would correspond to a wheel size. I believe the wheel size data, or revolutions/mile data for speedo is stored in PCM in Gen1 TC. Forscan (thus far from my experiernce) cannot read PCM on Gen1 TC. Hoping maybe i'm doing something wrong. PCM on my van (2013 United States), according to Chat GPT across broad cross searching, is the same make PCM used in 2010/2011 Focus. I've also learned perhaps the software ELMconfig can read PCM data, but I have yet to find a reliable download source for this software to try it. Also, there is vague reference that my AI has found that suggests a Ford Dealer may be able to read/write PCM module from Ford Focus 2010/2011, and thus might translate to being able to the same my 13 TC Gen1. I haven't gotten further on this lead. My ask above for someone else to corrobrate their data from their van (from a non US variant) is an a third parallel effort to help my AI run a comparison (since UK variants had a different standard wheel size) to see if that could narrow down information from the other readable modules (ABS, IC, BCM, VSM) modules that might correspond to wheel size. Again, for Gen1 TC. Well aware Gen2 TC this data is readable and accessible in at least 1-2 locations. More to update hopefully soon.... Edited August 11 by drum_buster Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted August 12 Share Posted August 12 One thing to keep on mind, Ford only wrote programming to support options they defined for a product line. The Gen 2 TCs have a short list of tire options Forscan can choose from. These are likely the tires the factory would have supplied on varions versions of the van. Due to the computer acthitecture, these are the only options we can reverese engineer. Other Fords like the F150, F250 trucks have a wide range of tire options. These trucks have a different computer architecture and users can input a large range of tire sizes once they have converted the tire size to a hex number. Even this has limits based on the max tire size Ford designed the softeare to handle (probably due to factory tire options). Finally, as of today the Motocraft site used to download factory as built data has been locked down by Ford. It is not working and you now need an account to even get to the proper page. Ford appears to be preventing users from reverse engineering the as built coding. I don't know how/what you are using for AI, but nothing that is accessible to normal users can accurately solve these types of problems. AI currently relies on forums like this for information and unfortunaly, there is a lot of misinformation on any forum and the information is not properly documented for a specific application (model, year, trim level, country etc.) Quote Link to comment Share on other sites More sharing options...
drum_buster Posted Tuesday at 10:44 PM Author Share Posted Tuesday at 10:44 PM Don, Thanks for more to consider. It is possible to pull some as-built data from the vehicle computer via Forscan, which is what I'm asking forum users to potentially share. I'm not completely following your statement about the Motocraft site with factory as-built data. Can you expand on that? would this have been additional info beyong what we can pull ourselves with Forscan? If there is any line of editable data in any computer that corresponds to a wheel diameter, rev/mile, etc, that is what most of the forums (across F150/250, Gen2 TC, focus etc) point towards sometimes being able to manually override. That's my goal to attempt. I hear you on AI - but it's another tool I'm using. But, every week it is growing in capabilities faster than we can comprehend, so though unlikely, I'm not ruling out that it somehow is combing information that you and I cannot access. Unlikely, but not impossible. Quote Link to comment Share on other sites More sharing options...
drum_buster Posted Tuesday at 11:01 PM Author Share Posted Tuesday at 11:01 PM On 8/11/2026 at 5:59 PM, Don Ridley said: Finally, as of today the Motocraft site used to download factory as built data has been locked down by Ford. It is not working and you now need an account to even get to the proper page. Ford appears to be preventing users from reverse engineering the as built coding. @Don Ridley, I was able to go and setup an account, enter the VIN, and get factory as-built data from Motocraft just now. Might try again if you previously hit a roadblock in your own endeavors. Quote Link to comment Share on other sites More sharing options...
