B1182, b124d, b1115, b109b, b1d79, u3003, b2734, p0734 Related codes due to bad battery?
After looking at all of the codes, most of them point towards an electrical issue. Not sure how long the van sat before being auctioned off, but I would start by checking all of the wiring harness for issues. Could be that the rats had a good time chewing up the wires for you. And while you are digging around chasing the harness I would check all of the grounding straps as well. Would also not hurt to put the battery on a good battery tester as well.
It turns out my blue driver obd2 scanner was malfunctioning. Now I have an o2 sensor issues and may need a new catalytic converter,  which may be why the DHL fleet operator let it get reported by the police and taken to a tow yard for auction.
