kruss77 Posted May 23, 2023 Share Posted May 23, 2023 Looking for information regarding the HVAC "blend door actuator" which changes the position of the "doors" inide the HVAC system to route or block heated/cooled air into the passenger compartment. Anyone have any experience with this problem? Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted May 26, 2023 Share Posted May 26, 2023 In the old Fords, for decades, the HVAC system had a series of actuators which helped to regulate the hot & cold air mix, and the which direction to blow the air (floor, dash, defrost). Those failed. They were difficult to replace. Sometimes requiring removal of the dashboard. Get a factory service manual for whatever model year you have. Sometimes, information like this is not in an over-the-counter Haynes or Chiltons book. Quote Link to comment Share on other sites More sharing options...
Phillip A Posted July 7, 2024 Share Posted July 7, 2024 Where is the blend door located on 2021 ford transit connect? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted July 14, 2024 Share Posted July 14, 2024 (edited) Here is information from a 2016. The 2021 should be similar. A Ford Focus uses the same actuators. hvac.pdf Edited July 14, 2024 by Don Ridley Quote Link to comment Share on other sites More sharing options...
