DW2207 Posted February 14, 2023 Share Posted February 14, 2023 (edited) Hi, bought a 2018 L2 lwb connect Uk spec. Had the van since November 2022. So far I've Fitted new 18 rs style alloys and pzeros Colour coded rear bumper and side sills 40mm eibach msrt lowering springs Btv custom rear door spoiler. I'm in the process of retro fitting the factory front pdc sensors. It's the limited model so had sync 3 rear sensors and camera as standard. Just no front ones. Signed up to forscan and got the correct obdlink ex cable and license key so hoping to get some help on here if possible folks. Cheers Dan Edited February 14, 2023 by DW2207 Quote Link to comment Share on other sites More sharing options...
mrtn Posted February 14, 2023 Share Posted February 14, 2023 TTIWWOP. There are some members here handy with Forscan. Please stand by. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted February 16, 2023 Share Posted February 16, 2023 On 2/14/2023 at 3:10 AM, DW2207 said: hoping to get some help on here if possible What are you trying to do with FORScan? Quote Link to comment Share on other sites More sharing options...
DW2207 Posted February 17, 2023 Author Share Posted February 17, 2023 So far I've been able to code the vans graphics in top right corner of sync 3 screen showing what rear pdc sensors are activated whilst reversing. Regarding the fronts, I think the stop start switch/ P aid button assembly ive got is for the 2019 connects. Mine being 2018 (preface lift) I'm almost certain this could be my issue for the front pdc sensors not being triggered. The switch internals may be working to different resistances. I've sourced the correct PN pam for this model of van. Just waiting for the new switch to be delivered. Checking my forscan logs shows that all the coding I've done and saved is all present and correct. Will truly know once I've fitted the correct PN switch I suppose. Quote Link to comment Share on other sites More sharing options...
