Rodduz Posted January 5, 2023 Share Posted January 5, 2023 Hi, my 2 rear barn doors won't unlock either key or fob. The driver and passenger are fine in one click, 2 clicks the front and passenger open and side door but back doesn't then they lock again straight away unless open one of the doors. Pressing just to open the back two doors the same happens, side unlocks rear doesn't. Anything that it usually is? Thanks Quote Link to comment Share on other sites More sharing options...
mrtn Posted January 7, 2023 Share Posted January 7, 2023 If yours is Mk1 it's a frequent problem, usually a bad BCM. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted January 7, 2023 Share Posted January 7, 2023 (edited) 10 hours ago, mrtn said: If yours is Mk1 it's a frequent problem, usually a bad BCM. Or it may be a bad actuator (hopefully). I would measure for voltage at the actuator when the unlock button is pressed. When you say the key does not work...you mean turning the key won't unlock? Maybe someone can clarify if the key turns a mechanical mechanism or does it activate a switch to move the electric actuators. *****Edit***** Maybe this? https://fordtransitconnectforum.com/topic/11425-all-door-electric-locks-are-repairable-for-7/?tab=comments#comment-41587 Edited January 8, 2023 by Don Ridley Quote Link to comment Share on other sites More sharing options...
