Rear doors not opening
Hi, my 2 rear barn doors won't unlock either key or fob. The driver and passenger are fine in one click, 2 clicks the front and passenger open and side door but back doesn't then they lock again straight away unless open one of the doors. Pressing just to open the back two doors the same happens, side unlocks rear doesn't.
Anything that it usually is?
Thanks
  On 1/7/2023 at 4:47 PM, mrtn said:
If yours is Mk1 it's a frequent problem, usually a bad BCM.
Or it may be a bad actuator (hopefully). I would measure for voltage  at the actuator when the unlock button is pressed.
When you say the key does not work...you mean turning the key won't unlock? Maybe someone can clarify if the key turns a mechanical mechanism or does it activate a switch to move the electric actuators.
*****Edit*****
Maybe this?
https://fordtransitconnectforum.com/topic/11425-all-door-electric-locks-are-repairable-for-7/?tab=comments#comment-41587
Edited by Don Ridley
