EmoMorales Posted August 29, 2022 Share Posted August 29, 2022 I installed a aftermarket head unit in my 2014 van and of course I can’t change the clock on the small screen. Is there a work around for this? I’m leaning towards just covering the top bar of it with black tape. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted August 30, 2022 Share Posted August 30, 2022 I assume you do not have Sync1 or Sync3 because these use the APIM module for clock functions I think. You can try changing the configuration to delete the radio. using Forscan but it will take time to learn what to do and cost about $60 for an adapter. It will be a little bit of a research project with some trial and error testing. Depends on how motivated you are. Quote Link to comment Share on other sites More sharing options...
EmoMorales Posted August 31, 2022 Author Share Posted August 31, 2022 Black tape………..done! Don Ridley 1 Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 31, 2022 Share Posted August 31, 2022 I have read of people retaining the original head unit in the glove box for this exact reason. Quote Link to comment Share on other sites More sharing options...
gossipninja Posted September 17, 2022 Share Posted September 17, 2022 On 8/29/2022 at 2:35 PM, EmoMorales said: I installed a aftermarket head unit in my 2014 van and of course I can’t change the clock on the small screen. Is there a work around for this? I’m leaning towards just covering the top bar of it with black tape. You have to hook the old keypad up (not sure if you need the disk player connected) to control that screen. If your dashkit has an "airbag" light, that is the connection the keypad uses. (at least for single disk, with 4.3 screen radio - no sync) Some android head units with canbus can emulate those buttons, but I don't know as with my android head unit i was able to remove the 4.3. screen completely. Quote Link to comment Share on other sites More sharing options...
gossipninja Posted September 17, 2022 Share Posted September 17, 2022 oh and i think you can use forscan to set the clock, but not positive. Quote Link to comment Share on other sites More sharing options...
