Air from the vents hotter than external air
Chip
My 2021 Connect blows air out the vents that is hotter than the outside air.
I put a digital temperature probe in the vent and compared the readings to the temperature reading on the dashboard, the vents blow from 7 to 15 degrees (F) above the dash temperature. I haven't tried this in winter. And I know when I initially start the vehicle the air is going to blow hotter for a while, but 15 minutes down the road, it is still hotter out the vents than it is on the dash thermometer. I made sure the recirc is   off and the temp wheel is turned all the way to cool. How is that outside air picking up heat?
Do all Connects do this? Or, is something amiss with mine?
Sorry, LnT, I didn't specify that the question is about the vent air with AC turned off.
It must be as Don says. One observation about the Connects is there is a LOT of windshield. Driving west in the afternoon, the solar heating is intense. I don't know how the air is routed under the dash, but it could potentially pick up a lot of heat from the dash. I also don't know where the intake is, but would hope it's not in the engine compartment. And I've never tried measuring the temp when it's dark. Might not be blowing as hot.
I have an a mount for my cell phone on top of the 4.2" display in the center of the dash. On a hot sunny day, the phone has shut itself off due to overheating.
Air intake is under the wipers. There is a plastic plenum that runs across the bottom of the windshield. My 2016 has a thin layer of insulation to slow down engine heat into the plenum. I briefly though about adding insulation, but decided it wouldn't much to lower the temperature.
I only use the vents without AC in cold weather.
  • 5 weeks later...
